Help With Correct Color Match Touch Up Paint..
Pappibri
Cohoctah, MI
I have an White 08 H3. I have heard people refer to the white ones as Birch White... Is this correct? And if so, do they make a Birch white touch up paint? They dealer does not have anything saying Birch, so I dont know which to get now.. Anyone know which one I need.. Thanks.:thumbs:
Xlr8n
Midwest
Give your paint code to the dealer to assure the correct color. GM is known for using the same colors on different vehicle models/years but giving it different names.
I picked up some paint for my "Solar Flare Metallic" H3. The bottle was labeled "Inferno Orange" (Camaro color name). Same paint code for both.
If you get the right paint code, it will be correct.
D
Dennis
Here are the GM OEM HUMMER paint codes with the GM code numebrs (it lists the same GM code number for Olympic white & birch white):
http://paintref.com/cgi-bin/colorcodedisplay.cgi?manuf=GM&model=Hummer&page=3&rows=50
Using this..I get; "Fine Silver Birch"..When in fact I know mine is "Boulder Grey"..However, the paint code is the same (WA926L) Strange..
You can find your paint code on the inside of the glove box door, right side..the number is at the top-middle of the white label, where your chin would about be when looking at it..
I order my touch up paint from "Autovisuals" ...the color match IMO, is perfect..
Pappibri
Cohoctah, MI
I looked while I was in Meijer of all places.. They had the Olympic White from GM which is what mine calls for.. The pen was $6.00 dollars, they wanted 12.00 at the stealership...:huh:
Scarsman
Monroe, WA
Try the stealth gray. My H2 is "stealth gray" but on the H3s they called it slate blue, but they are the same color.
cbetts
NERD!!!
Rancho Palos Verdes, CA
I thought they looked similar. I guess my mind was holding on to the word "gray" and wouldn't see it as blue. The chart only shows it for the H3 during 2006 and 2007 which helps confirm.
Thanks!
