STARR HID group buy
nj3talpha
Central Jersey
Starr HID group buy for H1, H2 or H3. Black or chrome For 10 sets its $660 shipped. For 20 sets its $630 shipped. Thats nearly 40% off!
H1:
H2:
H3: NJ3Talpha +1
[__--MUD--__]
South West Michigan
Just bumping as I have had these lights on my rig for 4 years now... Holy **** do they light everything up. You will end up having to aim them down significantly more than your stock lights, and you will get flashed alot...which is kinda annoying at times. I have 4 Piaas on my gobi rack, there is barely a difference in road lighting. The difference you see is really only from the outer floods lighting up off to the side. There is no light bleed above the horizon line of these lights like you get w/ the cheap HIDs in the stock housing. I have some pics somewhere (Ill try to find them) comparing the stock and these side by side.
If anyone has battery drain issue after installing these lights, the harness was not wired correctly. The lights will operate as they are supposed to, but power is never cut to the relays. You simply need to swap two wires in the harness. I believe this is documented on the Starr website.
Humvee21
Atlanta, GA
Not sure about this kit. I know Trucklites just released their new version of the 7" round LED headlamp that is supposedly giving out quite a good bit of illumination. I can name a few advantages of the Trucklite without having both products in hand.
1. Trucklite option is still cheaper without group buy
2. You won't have to mount a ballast as I believe the ballasts are built into the headlamp (someone can confirm if I'm wrong or not)
The only disadvantage I can think of is that the LED headlamp probably will not get warm enough to melt snow/ice buildup on the headlamp. That's something for you northerners to think of, though. Not a problem here in GA :)
Do you have a link for that Truck-Light? Their website is not the most easily navigated... I'd be curious to see the differences between this and Starr.
Humvee21
Atlanta, GA
The Truck-Lite is $500/set + shipping and produces 1800 lumens. The Starr is (potentially) $660 shipped and produces 3000 lumens. (At least from what I could find.) I'm not a lighting genius, but it seems like better bang for the buck with the Starr group buy.
Gunner_45
Texas
Does Truck-Lite have a lighting solution for the H3?
Last time I checked/e-mailed them, they did not.
Hence my hightened interest in the Starr product.
Humvee21
Atlanta, GA
I'm not a lighting person either. IIRC, light output is not only based on lumens, but please correct me if I'm wrong.
seventwozero
Fargo
As appealing as a LED headlight is, I'm not sure the technology is there... yet.
Mud posted some pictures somewhere, and from what I've seen the STARR kit puts out some serious light! Although, with the laundry list of things I actually need to do to my truck right now, these are out of my range :(
Good luck getting the group buy together though, they are worth the money from what I've seen.
I was wondering that myself. All I could find listed was a replacement for the H1. Perhaps the H3 is not supported.
Sent using Tapacrack
[__--MUD--__]
South West Michigan
If your taking in to condideration that your going to have to pop in 4 self tapping screw to mount the balasts- that seems kinda foolish to me.
The ballasts are remote, on the H2 they are mounted inside the engine bay on each side of the radiator.
I'm all about LEDS as additional accessory lighting, but personally I dont think they are ready for main stream primary lighting yet.
[__--MUD--__]
South West Michigan
MuDnYrI
Las Vegas
I have the Starrs and they are good. Not quite as good as my Old Mercedes ML320 Hella Projectors but good. $660. is a great price and the People over at Starr are great to deal with.
ReconH3
Guardian Angel
Raleigh, NC
I have them. Just never had the time to install them. When I get back it will on top of my list. Too bad this GB wasn't available when I got them.
"Ex Umbris Venimus"
Sent from my iPhone
