- Meridian, ID
I could also go to camburg. I've got a few ideas ill post up when I get on a computer
More excuse to run a 8.6 from the rear of an H3.there never was a dana 44 with c clips
Oh it matters. The 8.6 comes with an Eaton locker, matching 4.56 gears, and 30 years of improvements. You can cut the ends of the tubes off and re-weld them within inches of the pumpkin, you can use modern late model seals and bearings...easily available, it already has C-clips, and the spline count/shaft size is a vast improvement over anything else in its size range. Those are the only benefits I can see.I dont think it would matter if we started with a 8.6 vs an 8.5
5.48" Its currently lying in the rain behind a barn where I found it. The 8.5 (especially the 28-spline version) is a turd. Forget it. Move on.Could you get us a measurement of length from the crosspin to the edge of the cover mounting surface please?
Cute. D30s have a legendary rep...but only in XJs. I think the real issue is going to be oil-pan clearance...regardless of the axle. That D30 will certainly fit...pound for pound probably the strongest diff out there. However, I'm not sure it would take the abuse of 37" tires, 5.13 gears, and 6000 lbs of full-frame truck...especially with a V8.I attached a picture of the HP dana 30 we are working on for chevrolet S10 zr2 trucks and blazers.
You can pull an H3 rear diff and start chopping it without worrying about running reverse gears and such? I read somewhere that a buggy took a rear Dana80 and modified it for the front but they had to flip it. Does that apply?
These axles are considered to be the wimpy replacement for the D44,
I dont think it would matter if we started with a 8.6 vs an 8.5....
Remember, you're saving a grand by having the E-locker and matching gears already installed in it. Not only that but, all of your bearings, seals, and set-up is already done for you. You can simply un-load housing...do the chop...clean it up...and put everything back it the same position. I say this only because its a "prototype", and everything at this point is experimental. You can always do a re-gear to both axles after testing your IFS with stock gears.
