Definitely see your point. I guess at this point I see people that are able to talk to gm and get something out of it. But I'm not sure if they still have warranty or extended warranty. It also kinda of baffles me that my h3 was made in October of 2005 and if I'm not mistaken the bulletin that came out about the issue was in April of 2005. But then I see that they update the bulletin and include h3's made after the first bulletin by including the specific Vin numbers. Correct me if I'm wrong about the bulletin dates. The whole thing about Chevy Colorado's getting the extended warranty because of the head issue also brings up the point how come hummers weren't included? But there are really good points people make like stating that all cars could have a problem such as this, or the warranty point.
#PIP3935D: Misfire At Idle Due To Leaking Intake Valves - Supplement To 07-06-01-011 - keywords 2.8L 3.5L compression controls cylinder driveability DTC engine excessive head high L52 LK5 leakage leakdown low - (Mar 18, 2008)
Subject: Misfire at Idle due to Leaking Intake Valves - Supplement to 07-06-01-011
Models: 2004-2005 Chevrolet Colorado, GMC Canyon
2006 Chevrolet Colorado, GMC Canyon
and Last 6 of VIN Less than 287698
2006 Hummer H3
and Last 6 of VIN Less than 287591
This PI was superseded to update model years and engines, and to revise the repair recommendations. Please discard PIP3935C.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
On rare occasions, a SES light and P0300 may be experienced due to a single cylinder misfire at idle that may or may not be felt. This may occur before the VIN breakpoints above due to non-uniform intake valve seat wear, which may prevent the intake valve from sealing properly. Vehicles built after these VIN breakpoints contain harder intake valve seats to address this concern. If the engine misfires occur off of idle, this PI does not apply. Bulletin 07-06-01-011 contains a labor operation and related tips for performing a cylinder leakage test to diagnose this concern but it does not indicate what repairs should be performed if a leaking intake valve is found.
Recommendation/Instructions:
If the SI diagnostics do not isolate a cause for this concern, refer to the latest version of 07-06-01-011 and the "Cylinder Leakage Test" procedure in SI to perform a cylinder leakage test. If a leaking intake valve is found, replace the cylinder head by following the latest version of 06-06-01-017, which contains the necessary replacement procedure and part numbers. If the vehicle is a 2006 model, install the latest PCM calibrations to complete the repair. The cylinder head received from GMSPO contains harder intake valve seats to address this concern.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information
