PCMforless Electric Fan Kits
marshall@pcmofnc
Eliminate the heavy stock fan and free up power and gas mileage! Our kits include a black powdercoated laser-cut shroud, a high quality SPAL fan, a harness, hardware, appropriate brackets, and instructions for installation. With the 2008+ H3's, a patch will need to be applied to your PCM to operate the fans. This can be done with Hptuners software, we will also do it for free if you send it in (just cover shipping). Typical gains are about 15hp on a V8 and about 10hp on an I5. Gas mileage gains are typically 1-2mpg. With the 2006-2007 H3's, the fan will run off of our harness, which gets signals from a temperature sensor you will install into your radiator hose, and also from the A/C. Typical gains are about 10hp on an I5. Gas mileage gains are typically 1-2mpg.
06-07s are $375
08+s are $335
DIY kits are $325(you have to control these yourself via a switch/sensor of your choice)
http://www.pcmforless.com/index.php?option=com_wrapper&&Itemid=390&&goto=/shopping/H3 Electric Fan Kits.html
Ron46
Capt.
NJ
Since you bumped it up, i have a question about the fan kit too lol. The one thing I am worried about it having the fan on with mud or going thru water. Did anybody run a kill switch for it, or can it be done from the non diy kit?
Haha that was going to be my next question (kill switch)
Does it take up any more room then the stock setup?
I notice that a few part that work on the stock v8 don't work on mine because of the supercharger I have, just curious if this will be another one of those scenarios?
Ron46
Capt.
NJ
Thanks Paladine! Did you get the diy kit or the normal kit, and did you have the dealer re flash your pcm to have the fan work? Thanks. I'm really interested in doing this before the summer. The stock clutch fan kills power during the summer.
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
Normal kit, and yes on the reflash. My rig ran a little hot but the fan kept it manageable. The only thing that I don't like about it is the noise.
nrinzema
Grand Rapids Michigan
Anyone install this kit in an 06 H3 yet? I would really like to see how the sensor is installed into the radiator hose. Wouldn't like to intoduce a point for leaks to develop!
Sent from my SCH-I605 using Tapatalk 2
