seventwozero
- Fargo
I hopped in my truck after the gym today and noticed it seems like it isn't shifting the forward gears. I can shift from P/N/R and D, but anything past that, 1-3, you can't hear the transmission do anything. Driving around I'm not able to get it to shift either. I only life a few blocks from where I was at, so it was hard to tell where it was stuck, but it feels like 2-3rd as I don't have much torque at lower rpm's.
No error codes. No funny noises. Engine sounds the same. It drove fine to the gym, shut it off for a couple hours, turned it back on and now this!
Has anyone encountered this? Thanks.
edit:
I found this http://www.355nation.net/forum/serv...utomatic-transmission-stuck-2nd-3rd-gear.html post about a bulletin for the 05-06 H2 being stuck in 2nd or 3rd, is it possible it applies to 04 too?
UPDATE
I just heard back from the dealer, the issue was the transmission wiring harness. He didn't say exactly where, but the tech found a spot where the harness was pinched and had cracked or worn the jacket of a number of wires, causing a handful of errors. So, an entire day of shop time, parts and a $80 diagnostic fee and the problem is fixed for $450. On the plus side, this should also fix the problem I was having with my intermittent speedometer!
edit:
UPDATE
