Front diff mount
Jester
Mesa Az
Does anyone have a suggestion on what to replace the front diff mount (cross member) with? The dealer wants $400 bucks for the stock one and I can't get the guy on here that has the rebuilt ones to answer me back.
H3slate
Brush raked
Tualatin, Oregon
Is just your bushing bad? You can try suspension.com, they have a replacement bushing kit. Pretty easy to do yourself, I had to cut down the bushings a little to fit snug, but it has held up well. You will want to call them to order it, I couldn't find it on their website. I called to order mine when I got it.
http://www.suspension.com/
Is the guy you are trying to reach Duane? I know that he just moved shops, you could always pm BigUnit or Alrock and they could get you in contact with him. His solution is nice because you get a better than oem bushing in the crossmember.
If you can't get in contact with him, pm me and I will get you in contact with him. Absolute great guy to deal with
backcountryislife
Dumont, CO
FYI, I've got the full energy suspension bushing kit that someone suggested when it happened to me, I'll ship it to you for $25 if you want to go that route.
Preferred Chassis Fabrication is a forum sponsor and has a solution ready to go in - undo some bolts and pop in a new crossmember. PM him here on the forum.
Bebe had a really nice write up on replacing that bushing at one point. Not sure if that thread is still around, but that fix works very well and is quite a bit cheaper than the full crossmember replacement.
