Does anyone have a suggestion on what to replace the front diff mount (cross member) with? The dealer wants $400 bucks for the stock one and I can't get the guy on here that has the rebuilt ones to answer me back.
Is just your bushing bad? You can try suspension.com, they have a replacement bushing kit. Pretty easy to do yourself, I had to cut down the bushings a little to fit snug, but it has held up well. You will want to call them to order it, I couldn't find it on their website. I called to order mine when I got it.
Is the guy you are trying to reach Duane? I know that he just moved shops, you could always pm BigUnit or Alrock and they could get you in contact with him. His solution is nice because you get a better than oem bushing in the crossmember.
FYI, I've got the full energy suspension bushing kit that someone suggested when it happened to me, I'll ship it to you for $25 if you want to go that route.
Preferred Chassis Fabrication is a forum sponsor and has a solution ready to go in - undo some bolts and pop in a new crossmember. PM him here on the forum.
Bebe had a really nice write up on replacing that bushing at one point. Not sure if that thread is still around, but that fix works very well and is quite a bit cheaper than the full crossmember replacement.
