WTS 2006 lifted H3 for sale
I think it's time to part with my H3 and move on to something else... *My truck has a ton of mods and it's really been a good truck. *I'm not even sure I can list everything... *it started as an 06 base in red with the luxury package (leather, monsoon)...
Rancho front, Soa rear
Bilstein shocks
1" body lift
35" duratracs
Stock wheels painted black w/ motorsports tech 1.75 spacers
Tatton front shaft/ custom longer rear shaft
OD rack mount/ diff bushings
Newer style 16mm tie rods
Thorparts bumpers
Oem ucp (modded) and sliders
Ported tb
ProDry S filter
AirDoc intake
Pcm of nc tune (89 octane)
4:1 t case
External trans cooler w/ pusher fan*
Smittybilt x2o w/ synthetic line
Rockhard license plate kit w/ light
Yakima megawarrior w/ extension on 3 factory crossrails
(Hi lift mount, shovel mount)
Aurora LEDs (2 back cubes, 2 front cubes w 10" bar)
Brushguard/ taillights guards
Arb 6' awning
Diy Swaybar discos
Auxilary fuse block for accessories (no rats nest of wires)
Cobra cb mounted in dash w/ Kenwood cd player.
Rockford fosgate speakers and sub in factory monsoon box.
There's probably more that I'm missing. *Little stuff here and there. *Oh, like the diff guard... *Lol. *I have a lot in this truck in the form of time and mods. * It's only been wheeled once since the lift (bout a year or two ago) and a handful of times before that. *Leafs were both replaced a little before 100k. * Lift went on after 100k. *All front end bushings were replaced with the lift with the exception of the UCAs. *T case has probably 30k on it. *Bought that new. *Stayed on top of fluid changes regularly. *Royal purple in the diffs and t case. *Valvoline synthetic in the trans. *Synthetic in the engine every 5k... * Oh, there's a drain plug in the trans pan too... *It's got a manual trans radiator (no internal trans cooler). *Just replaced a driver's side wheel bearing and drivers side cv. *I damaged the boot of the cv replacing the hub. *I will include the old cv w/ a new boot kit. *(Not installed yet. Lol). * I still have to original 2.6:1 t case, rear shaft, front shaft (bad cv joint). All that can go with the truck. *And anything else I may have laying around still. *The door handles, mirrors, hood corner pieces, hood panel have been bedlined. * It's ****ty and needs redone. *Spend $100 and get all new handles. *The rest can be redone fairly easy... *That's really about the worst part of the truck. * Oh, the drivers door switch just started sticking ($5 fix) and the Evap canister solenoid is throwing a code ($60-75)... *The only other codes I've ever seen before were coil pack codes so there's a couple newer ones of those in... *It's had the head work done but not the latest blower motor connector recall done. **
I'm not gonna fight with the photo uploader and post a million pics. *If you or anyone you know is interested, we can exchange numbers and I can send photos of anything you want. *I really do feel like I'm forgetting stuff, like the fire extinguisher and maglite in the rear compartment...
I'm thinking somewhere around $13,500 should do it. *I'll double check and edit if necessary. *Figured I'd put it on here for a few days before it gets traded in... * Inbox me and I can send you my contact Info...
rsc
Tulsa
Wish I had the cash at the moment, that's a well set up rig. Hope it goes to a good owner.
