2008 air bags don't hold air overnight
tdinardo
key largo, fl
How common is it for an air ride equipped truck to not hold its air overnight?
I had it into the dealer, who saw it happen while it was there, said it wasn't supposed to do that, but also could not find anything broken. The bags refill about a half mile after I start driving.
What is odd is that this is somewhat intermittent in that it will happen a few days in a row and then not for a few days. It's driving me nuts.
Any ideas?
scoreh3
My neighbors H2's air ride is leaking and he's tried to fix it , but the coil conversion sounds like a better fix. Is the conversion a kit or custom conversion ?
Synthetickiller
I've never done it, so I can't comment on which kit, but if you google "H2 coil spring conversion," you'll find your answer. As for which is the best kit, I can't speak to that.
scoreh3
Thanks I will check and tell him . This is what I like about this forum , you learn things you didn't know you needed to know .
twinmill28
Spilled Milk
Pants on the ground, pants on the ground. My deuce has joined the "dog dragging butt club". Pretty sure it's the bags as I hear the pass. side blowing air the other day. Of course I'm out of town for two weeks so it's got to wait 'til I get back. Not like there's a massive rush to replace the bags in El Centro's 110 degree temps.
Do you guys have recommended source for replacement bags? I'll check the usual, Ebay, Rock Auto, under Zach's truck (but I think he might be catching on to me as he painted his last set of bags bright pink and in order to match up my old ones to put under his truck I couldn't get the paint off my fingers for a week plus my new bags were kind of, uh, Fabulusss!).
Oh and since I actually tow ALOT with the deuce, no goofy recommendations to lower my standards and go with springs (ugh)
Good ole Twin! Bags are a fairly easy and inexpensive replacement. I don't tow, but love the ride compared to springs. It is noticeable
tdinardo
key largo, fl
Also, what is the best method to confirm that the bags are actually the failed part. Nothing worse than replacing stuff only to find out it wasn't the broken part.....
Get a spray bottle with soap and water. Squirt the air bags really good and look to see if there are any bubbles. If so, air bags are toast
HUMMERDAD
GraysLake IL
Make sure to get it up off the ground too thats where my bags were leaking so you could not see it until she was on the lift up off ground suspension fully flexed. with truck sitting on the bags my leak was on the bottom of the bags so it didn't always leak at first, but when the they where fully expanded out you could see the wholes with the soapy water.
