chaos254
- United States
I have this clunk when making sharp right turns that i cant seem to figure out. It is definitely coming from the left side and sounds like it's coming from underneath my feet. It seems to be worse over bumps. I checked it over with one of our mechanics. Swaybar links are tight, upper control arms are good, no play in the tie rods. I have a little bit of play in the driver low ball joint but nothing that should be causing this type of loud clunking. Rear lower control arm bushings are dry rotted but also shouldn't be making this noise. CVs look fine, also no play. No play in the hubs, stock rack bushings but also no play. Shocks are original but no leaks. Both steering shafts are new(fixed a bad clunk i had before)Can't get the noise to happen on the lift but it happens every time I drive. Any ideas would be great since its driving me crazy!
