Coolant Low
derian06
Red Rockett
Madison, AL
I had my radiator replaced about 5000 miles ago and the coolant is this low
does this indicate another problem? Is this normal? Is the radiator bad again?
poweraidon
georgia
It could the air bubbles... But refill it again if it loses coolant again you'll know something is not right. Maybe bad radiator cap or leaking hose
Peep
Belize
Duh!
Just checked mine and its at the same level as yours.
Damn, knew I should not of drove through the Rockies on my 5000 mile trip to Belize
That's about where mine likes to be, maybe 1/4" lower. Mine never stays at the cold line.
As mentioned, top it off. If there's an issue it will become apparent but this, for me, is normal
Panzer07
Ontario, CA
Same thing happened to mine when the dealer replace the radiator...which leaved me to believe that they either didn't too off the radiator or didn't change the fluid...I too it of and haven't have an issue tho so who knows.
Duh!
Colorado is hell on Hummers.
Seriously though, if you replaced your radiator and it gets low again.... do you smell antifreeze in the cabin? Did you overheat it before you got the new radiator? Have you done any severe-duty wheeling or pulling?
derian06
Red Rockett
Madison, AL
None of the above, check engine light came on, it wasn't overheating, but 3 shops said it was a radiator problem.
H3Hrly
California
Mechanic found a 7-9" crack in my radiator. I never saw a leak nor smelled an odor. He mentioned that the pressure during use vs pressure when off could have been enough for the radiator to leak while operating but not when off. He also mentioned that due to the materials of the radiator (plastic on top and bottom and aluminum in middle) that the high temperatures and changes in temperatures wears down the structure of the radiator over time. I'm not a mechanic, nor am I even slightly knowledgeable on this topic; just sharing my experience.
It takes awhile for the lines to seal back up, however, I'd expect they'd be done at 5000 miles. What I'm thinking is your heater core has gone as well... same materials as your radiator
derian06
Red Rockett
Madison, AL
derian06
Red Rockett
Madison, AL
Update, i didnt mean the check engine light is on now. Those where what happened when i had my radiator replaced. There is absolutely nothing wrong with my hummer right now.
