- Bellflower, CA
I tried to seach here but no luck. Looking for the best way to remove the complete dash. The radio bezel is easy but I'm looking to remove the complete dash assembly.
Shows everything but the dash. Go figure.This should have all the info you need about interrior trim:
http://schwarttzy.com/wp-content/uploads/2013/01/Hummer-H3-Interior-Trim-Paneling-1.pdf
Please explain?You don't have remove the dash to do that
Oh really? I didn't read the whole thing.i figured it would be in there based on the categoryShows everything but the dash. Go figure.
Power to the dash tray - remove the tray, run a fish tape through the hole with which you secured the tray. You can run power through there, that's how I did my CB. You'd just need a small hole in the dash tray. Others have done this as well. Heck you can even run power up the side of the dash and tuck the wire between the windshield and the dash, which is how my CB coax is routed.Please explain?
