H3 DOI Winch Mount
FormerUser
Where do I send the paypal payment? Seriously - if you could drop me a couple of pics after you've got it done, that would be fantastic. If what your planning on fabbing mirrors the white GM Moab H3, I'll take one. Looking at those pictures, its apparent GM was trying to mimic the H2 for a front mount. While I haven't had a chance to stick my head head in between the frame rails, I think the frame is predrilled for such a mount(like GM had planned on releasing a accessory?). Anyways, my excitement is up and I'm looking forward to this. My H3 is a 2010 Adventure - the last one.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
According to the Curt Manufacturing install instructions, there are two pre dripped / punched holes in the frame. These are the mounting points I intend on using. Let me throw up a picture really quick.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
Here is a picture from the install instructions of the Curt Manufacturing receiver.
Here is a crude MS paint sketch on how I intend on doing mine (this would be the inside of the frame rail). The hitch itself is not picture but it would be attached directly into the crossmember and come out at tow hook height. This just a quick and crude drawing for reference and there would be plenty of gussets for added strength.
Looks like a cool solution. On my H2 SUT I had the Warn 9500 and had the Warn cables to both the front and back so I could move the cradle back and forth as needed.
JR3T
CA
Finally got around to replacing the rollers. :)
I have noticed those with the DOI and traditional fairleads DO dig into the ground a bit on sharp approach angles. Witnessed it many times when spotting JR3T. I'm not saying this is a significant disadvantage but it can present itself on occasion. I wouldn't mind having this winch mount.
Vs these H3s where there is still light under the bumper
Portager
Silverado
NICE!
Me likey
Sent from my Galaxy Nexus using Tapatalk, which removes "unnecessary" returns.
JR3T
CA
Just curious when u order the doi winch mount what else do u need to order with it. Fairlead separate .
You just get the bumper winch mount from DOI.
Contents of box.
Winch comes with most hardware you need, including the fairlead. But, I would not recommend using the roller fairlead with the DOI mount. Just changed it out for a Hawse fairlead to improve approach angle.
It's also a snug fit for the winch, which limits your options for winch choices. Think only 2 or 3 models fit in there.
Australia
All true, but I don't consider most of your points detrimental. Also the winch is actually aligned with the frame rails, not below them.
I wanted to maintain the stock look, approach angle and minimize the weight that was adding forward of the front wheels. Weight that is cantilevered out in front of the wheels is very detrimental to steering and handling. I called DOI and talked to the designer, Defeliece. He designed the bumper/winch for a SEMA show truck that 4 wheeler magazine did for GM. GM engineers reviewed the plans and although they didn't provide approval they also didn't suggest/require any changes either. DOI intentionally kept the winch in line with the tow hooks to eliminate bending moments which could bend the frame. If you don't do this you must re-enforce the frame, which adds weight. I talked to Defeliece and he said the Warn XD9000 was the only winch that they mounted in the bumper so I choose that winch and it fit perfectly. I didn't want a bigger winch than 9,000 lbs because 9,000 is big enough for a 6,000 vehicle and I wanted to minimize weight. He also rotated the winch base so that the base is pointing forward into the structure of the bumper. This eliminates shear stress in the bolts (every mechanical engineer knows bolts are never supposed to be loaded in shear but it is done so often that non-engineers think it is OK) the only downside is the bolt heads are visible in the front. He rotated the winch within the mount so you can access the reversing level and he hid the connector for the hand control inside the grille.
To reduce weight even further and to make the line easier to feed back onto the winch, I went with synthetic winch line. This saved about 18 lbs if I remember correctly and it is much easier to feed. This helps a lot since access/visibility of the drum is restricted. I also went with an aluminum Hawes Fairlead to avoid pinching the winch line, reduce the front protrusion and improve visibility of the drum.
I mounted a new license plate frame just above the Hawes Fairlead so it is out of the way of the winch and doesn’t block air flow through the radiator.
The build quality of the DOI was great and there were no problems with installation.
Personally, I like the looks of the DOI bumper and I wouldn't change it. I only use my winch when I get stuck, so I use it very rarely (O, I haven't used it yet except to test it). Therefore, way compromise looks and handling to improve usability of something that is rarely used. That said you do have to be very careful when rewinding the winch.
Here are some pictures of my bumper and winch.
Hi mate,
I'm in the market for a hiden winch mount for my H3 and like the look of yours. I have tried to look for the details for DOI but unable to find. Could you please share the details ?
Regards
Raphael
Alpha X
The Motor City
Hi mate,
Regards
Raphael
Last post in this thread was 12 years ago.
Check out this hidden winch mount from Schwarttzy:
