FS - Spare Tire CB antenna mount
sinstr
south fla
Firestick antenna mount, everything you need to mount a CB antenna behind the spare tire using the existing mounting holes. Includes antenna cable.
$15.00 shipped
Medic_Morgan
San Diego, CA
Ok I'll take it. ;) I'll PM you tomorrow about the details for that, the SG II and possibly the PCM
Sent from my secret lair bwaaahhahahahah
chad
florida
best way to route coax into the cab from the back is from the air vent through the wires going out the side of the door down the side of the trunk under the cargo mat and under the carpet which can come out by the vent under the seat or from the carpet end under the floor boards, i did a little cutting on my carpet though, the carpet is one big piece so i cut it to two pieces to make taking it out easier and you cant see it with the floor mat that goes across the whole back floor. it sounds like a lot of work because all the seats need to come out for the carpet to be removed but its not as bad as it sounds.when its all done it looks good, i routed a couple extra wires through for future mods if i want to use them.
h2005
Northern Arizona
Do you have any photos that shows how its routed? Can it be routed on top of the frame and into the cab?
