CLajoie222
- Ohio
Hello!
I have several items for sale today for an H2, years 2003-2007. Obviously the condition will be taken into consideration, so I'm open to all REASONABLE Offers as some items are becoming harder to find and are obviously discontinued. Examples such as the Wheat Colored Door Panels or the Interior Trim Pieces. Enjoy!
1. Upper Dash Cover, Part #15142915:
Overall good shape except for 1 small crack that was stopped with super glue and it’s about 1 inch in total length. The crack started by an overtightened screw which led to one of the “tongues” or tabs to split/crack and break causing a small crack to spread and become visible. Theres a total of 2 broken “tabs”, one on the left side and one on the right. Again overall good shape, especially compared to someone who's cover has already cracked all the way through and the corner separated, or the anti-reflective coating has started to flake off!
2. Complete Dashboard Kit, Part #N/A: (Individual part numbers available if needed.)
Overall good shape, especially for being an original piece. Their all in the original metallic color with a few paint touch up spots here and there to cover scratches or worn off paint. The main center stack cover has 1 small hairline crack that I'm positive can be repaired and repainted and you'd never know the difference. You can't see it too easily without close inspection, hopefully that helps give an idea. The other pieces are in quite good condition with only minor paint wear. It’s cheaper to repaint and customize this set v.s. paying the ridiculous prices for each piece on eBay, especially for a brand new set if you can find them. Last time I checked a few months back a FULL set was going for almost $1,500.00 plus shipping or over $500.00 for only half of the set, or at times just for the center stack. These in a complete set are becoming scarce and selling them piece by piece is what your finding more common online unfortunately, which comes with an out of touch price tag per item.
3. Driver Side Door Panel, Part #10358790:
Overall great shape except a small crack near the door handle which is actually pretty common for these door panels, especially for it’s age. It’s covered by a large GM Silver Emblem, simply peels off if desired since it’s just double sided tape. The silver metallic trim around the handles is worn but has been touched up in various spots but can be professional repainted or DIY at your discretion. The leather is in great condition, free from defects or issues. The armrest has been reinforced on the backside with a bonded cast to help protect the door panel from stress, wear & tear as that corner is rested and pushed on more frequently then any of the other door panels. It has definitely stiffened up the arm rest with zero flex or creeks whatsoever!
4. Passenger Side Door Panel, Part #10358792:
Overall great shape except a small crack near the handle, similar to the driver door panel. The leather is also in great condition and free from defects. The small crack is covered by a large GM Silver Emblem, simply peels off if desired since it’s just double sided tape. The silver metallic trim around the handles is worn but has been touched up in various spots but can be professional repainted or DIY at your discretion. Otherwise zero issues with the door panel!
5. Rear Cargo Mat, Part #12498331:
Thick heavy duty cargo mat that came standard from the factory for all H2 models, helps protect your rear carpet from anything from dirt to corrosive items such as spilled gas from portable gas cans or chemicals in case they leak or whatnot v.s. sitting on the bare carpet.
6. Front Bumper, Part #19178491:
Primed and painted from the factory and ready to bolt on, with 1 small defect. It has a small dent located in the lower left section right near the cut out for the front tow hooks up front. I will attach pictures, You can simply touch up the paint if you wish so that it will not rust and you can use it right away and probably never notice it there in the first place. Or you can hammer it back out flush with the rest of the bumper and refinish that small area for a flawless appearance if thats what you wish. I replaced it with a new one because I have neither the tools or the time to fix it. Either way it’ll be a great deal for you!
7. Hood Blanket Insulator Pad, Part #15800593:
Overall decent condition, with a faded appearance, which I’m sure can be corrected with some form of paint, dye, or possibly a good cleaning. There are a few small tears in it but those can be re-adhered with various automotive adhesives or sealants/glues.
*Reminder, don’t forget there are no set prices, but open to all reasonable offers!
If you have any questions feel free to ask and I'll get back to you as soon as I can!
Thank You!
Thank You!
