- Tardville
Stick build em! You are now officially a fabricator right?
one I believe. My original had one also.
CJ, Im willing to try it, if they suck I will take em off. Are they a fab job or a CNC type deal?
Nice looking stuff. Poly would be the ticket for sure...maybe a tad more time consuming to fab. I would like to draw some up on CAD and laser cut some pieces to produce them. I'm not real crazy about stock H3 motor mounts. Next time you got the hood up, have somebody jump inside your H3 and power-brake the truck up to 1500 rpms (forward and reverse). Stand back and look at the motor...you won't believe how much the 5-cyl. moves around! I've even pulled my AirDoc tube off the intake before. More attempts by GM to make a fluffy Cadillac out of a Hummer.
Anybody driving a SASH3 without a real bumper, already has the "structural engine block" whether they realize it or not. There is at least one SASH3 driving around (who shall remain nameless), where the engine block is the only thing holding the frame rails in place. -LOL
Energy suspension 9.9488 is the isolator you need. You will need to trim about .006 off the inner sleeve to get it to fit in the perch.
The inner perch can be prepped by cleaning the small locator tabs on the inside of the perch and enlarging the bolt hole from 1/2" to 5/8"
This bushing fits in a 2.5" od 2.0" id dom tubing. I'll have to look up the length, just a tad more than 2.25" I think.
These are mighty stiff with my 4bt. I wish I could find the same insert in a rubber instead of poly.
Nameless huh lol reporting in brotha ;-)Nice looking stuff. Poly would be the ticket for sure...maybe a tad more time consuming to fab. I would like to draw some up on CAD and laser cut some pieces to produce them. I'm not real crazy about stock H3 motor mounts. Next time you got the hood up, have somebody jump inside your H3 and power-brake the truck up to 1500 rpms (forward and reverse). Stand back and look at the motor...you won't believe how much the 5-cyl. moves around! I've even pulled my AirDoc tube off the intake before. More attempts by GM to make a fluffy Cadillac out of a Hummer.
I really haven't even looked at the motor mount situation but, if its like everything else on the H3...the available space is going to drive the direction of the design. Basically, I think you'll have to get the poly sleeve in wherever it will fit. I doubt if there will be much of a choice on where to locate it.
No crossmember on my rig. The THORparts front bumper is the crossmember...out at the ends of the frame rails. Next is the transmission crossmember, back at the doors. Of course the motor also serves as a crossmember -LOL. The original bolt-in diff crossmember under the motor, goes away with the SAS and so does the welded-in rack & pinion crossmember. So you definitely remove a bunch of beef. After the chop...the oil pan is fully exposed and there is no room to add anything directly below it, due to the live front axle.
I dont know if I wanna go back to OEM because he said he has seen this before. So I am going to avoid stock if I can
