Spent all day wrenching on my truck. It is 500 miles short of 100,000 and it is showing it's age.
The plan: Replace both upper control arms, replace front diff with slightly used front diff, replace engine mounts, replace bushings in the steering rack.
Well, I got the front end torn apart, both upper arms off, front diff has been removed, and I got the new engine mounts installed. My passenger side mount was shredded, drivers side was not too bad.
This is what it is supposed to look like.
When I was removing the upper control arms I came across something that was pretty stupid. The bolts are both on the inside of the control arm, one of which you have to remove the brake line to remove the bolt. The simple fix to this would have been to have the bolts on the outside of the control arm and the nuts on the inside. :roll:
