lifting the rear of the hummer h3
Leaf spring shops can re-arc the springs the other way too (flatten them out) ...using a spring arcing machine. I've seen it done. Take your tk to a spring shop ...they can make your tk the height of your choice for not that much $$ and about an hour of time.
aspen
ct
found a spring shop to re ark my rear leaf's. that will be done in the next week add 2 inch to the ark .
aspen
ct
need second opinion to be sure this is for our hummers Morris 4&4 center tuff country 5 inch lift for 2,500.00
if so great find
aspen
ct
more investigation is not good news going to get a return call about the product and if they can make up one .
hahaha for 2 inches in the rear kind $$$$$$$$
If I recall correctly, only 2 lift kits were ever made for the H3. Rough Country, which didn't have good reviews and didn't last long, and of course Rancho. Your best options for raising the rear end have already been presented.
aspen
ct
aspen
ct
already took care of the rear springs .
may fab my own lift at a garage i go to
aspen
ct
Late to this thread, but I thought I'd show what I got when I refreshed my suspension. Decided to get OME leafs, the Schwarttzy high clearance u-bolt plate and his shackles (pictured). It was way too high in the rear. The rear view mirror became useless.
I ended up taking out the shackles, but even then it is stanced high in the back, lol.
23.5" torsion crank at the front. I might pop it up to 24.5" just to level it out a little at the expense of the CVs.
dam that loos really high in the rear how many inches did you add.
aspen
ct
well went with the re arching the springs up 2 inches .
glad i did while i was taking the springs off 1 was broken so getting new springs ome and re arching
Gent
Canada
Not really sure. I think I read that the OME leafs add 1.5 to 1.75”.
The Schwarttzy extended shackles do 1.25”
The high clearance leaf spring bolt plate adds about 3/8”.
So somewhere between 3.1 and 3.4 inches; I took out the extended shackles though so it’s more like 1.85” high now. Still a noticeable rake, but not as crazy.
aspen
ct
i did 2 inches re arch on my springs makes really hard to reinstall
