Looking for help with wheel spacers....
ffmf2101
London, Ky
I'm wanting to order some custom wheel adapters for the factory wheels from motorsport tech and having a little trouble coming up with the info that I need. I have tried searching the forum and not finding the exact info that I need.I know that spacers would be easier but the 1 in is the biggest that they have.
06 Hummer H3
bolt pattern--- 6x139.7mm
hub diameter-- 100mm
centric to hub & wheel
thickness ------38mm or 1.5 in
stud size ------12x1.5
center bore of wheel in mm --100mm
bolt pat5ern diameter of wheel--6x139.7
I think that I am correct on this but just trying to make sure before I order.
Panzer07
Ontario, CA
I would personally call them and place the order by phone...they know exactly everything, you just got to tell them how thick you want the adapter to be and for what vehicle it is going to be...that's what I did because I had no clue about the measurements.
Panzer07
Ontario, CA
I'm running 1.75 inch adapter so I can run the stock wheel rims with the rancho as well I like how the tires stick out.
derian06
Red Rockett
Madison, AL
06 Hummer H3
Just call them and tell them it's for a hummer h3 and they already know everything... Or atleast they did when I ordered them a week ago.
humvee
Doha, Qatar
Motorsport tech make the best adapters, I'm running them on my 3. They take longer than intended to produce, but once you get them you'll forget about the wait.
Mine are not hub centric because I moved them over from my Mitsubishi Pajero. But they are so well built, and the material is so balanced that I do not get any vibration.
Bought a set off eBay for my uncle's FJ... vibration was horrible even though they were hub centric (didn't understand why), I'm convinced that Motorsport tech is always the way to go.
