NOW AVAILABLE: The H3/H3T Scorpworks Bushing Front Diff Crossmember
06BlueH3
Missouri
Old nut
Okay. How do you remove old nut that the center bolt screws into so you can put in new bolt supplied by Scorpworks. Nobody ever mentions it. Sorry if a dumb question, but it's the only thing holding me up from finishing.
06BlueH3
Missouri
Thanks. I'll try to pry it off. It looked like it is bolted on and I could not find what size Allen wrench the bolt is.
06BlueH3
Missouri
Okay, I was able to remove the retainer clip that holds the nut in place.
A torx shoulder bolt holds the clip in place. I pressed out the old nut and pressed in the Scorpworks nut and reinstalled. This should ensure nut does not come loose.
06BlueH3
Missouri
Okay. I packed up my old crossmember and will be dropping it off in the morning at FedEx to return to Dwaine at Preferred Chassis Fabrication.
KristianH3
Do you have any updated pictures from the bery first post that you made? Everything from way back is not working anymore and curious to see how they all look like
Hummer88
texas
I tried calling and email I would like to order the h3 bushing /crossmember. can you give a call when you get the chance 432=661=5655 ron thanks
D
Deleted member 7876
I'm curious if these cross members are still available? I believe mine isn't doing to well. I'll know in a week or two when I get back to the Hummer to have a check. But I noticed, with a quick step on the gas, she clunks underneath.
Dwaine has been unable to keep this in stock due to virtually none of his customers returning their old ones for cores. Guess he should have charged a much bigger core fee.
Korby7
Utah
I have a crossmember I could donate and could ship Moab express. Anyone live close to Dwaine that is going to Moab this spring?
D
Deleted member 7876
Thanks for responding 3Hummers. Yea, sent him a PM but no response.
Guess I'll see if I can get the kit from Outfitters.
D
Deleted member 7876
Too bad, would've been great just to replace the cross member instead of dealing with the bushings. Oh well, it is what it is.
Sent from my SM-G965U using Tapatalk
