I installed a MaxTow gauge on both my base I5 and my Alpha, and both of them kept the factory sensors (switch in the case of the I5).
The I5 (3.5L/3.7L) you just add a tee at the factory location so that both the oil pressure switch and the sender for the gauge have a home. It takes a few fittings to adapt it but it's pretty simple to do.
For the V8 I used a bypass plate (the 5.3L often has an oil cooler plumbed in after the filter but not on the Alpha's for some reason) that had a tapped hole in it, the factory sender is at the top back of the block.
