H3 Piston slap
arkalpha
arkansas
2008 Alpha has a noise in the motor. I've been told it sounds like piston slap. Anyone experience that and or have an idea or a solution that worked for them?
Ghostbuster
How many miles? Try Risoline engine oil treatment. Also might wanna try there fuel system cleaner. Good stuff. If that stuff doesn't work then do a motor flush. Hope that solves your problem.
woodwardsh3
Oakland Co. Mi.
I had a 2000 gmc 4x4 with the 5,3 and it was load on a cold start up. But when it warmed up it was gone. Is it still doing it after it is warmed up. Have you checked for a cracked exhaust manifold or broken studs / bolts that can make a lot of noise too.
arkalpha
arkansas
115,000 miles. Regular oil changes. No exhaust leak and yes warm or cold it doesn't matter. I've had a few people say sea foam, but I didn't want to try anything until I checked hear to see if it was fairly common.
