napalmsticks
- NM
Not too sure if everything is related so I will start from the beginning. Sorry for the wall of text...
Went down a pretty wet and muddy trail the other day in 4 high lock, didn't seem to be any issues. After this romp a couple days ago while driving to work the ABS fail and traction control fail message comes up on the display. I get to a red light come to a complete stop and it went away. Took the front passenger wheel off as something sounds like it is rubbing, everything looks good and I put everything back together.
I noticed around the same time my front prop shaft CV was spitting grease and decided today while waiting for my new drive-shaft I would remove the shaft and drive in 4 hi lock. I clicked it over to 4 hi lock in the driveway and removed the front shaft. After removal I back out of the driveway and start driving around the block to check everything out. I got about two blocks and the truck quit moving. The front output from the transfer case was spinning but doesn't seem to be locked with the rear. I threw it in park, put the brake on, get out, and spin the front output by hand, not locked. Get strapped back to the house and put the case back in 4 hi open. While I put the drive-shaft back in with the TC open it was locking with a pronounced click. The front output shaft would quit moving. I click it over to neutral and let it roll to attempt to get the holes lined up with the shaft and it will unlock followed by it re-locking when I move the output shaft by hand.
Also during this whole debacle I lost my fuel level sensor. Low fuel came up in the display with needle on E, turn the key off and back on fuel level is back.
Anyone have any thoughts?
