H3T Problem with rear torsionbar with nearly full loaded car
Azon
Sweden
Hi i have some problem with rear torsionbar on my H3T, when i put my camper on ( approx 500 kg) the trosionbar collide with rear axel. has anybody seen this before ?
Azon, that is the rear sway bar not the torsion bar. Never seen that happen before. One of the causes could be that you are overloding the bed of the H3T with your camper (500 kg = 1102 lbs.). The payload capacity of the H3T bed is 1,090 lbs/494 kg, that's only a difference of 12 lbs. I wouldn't think that could be the cause. Maybe you are exceeding the rear axle curb weight with all you other gear packed into the camper (the rear axle curb weight is 2456 lbs/1114 kg). Maybe your leaf springs are worn-out & need to be replaced.
Wow...that's first for me. Guess that's why I've never seen a camper on an H3T! Have you weighed your rig before and after to see just how much extra you're adding?
SkinGripz
Horse Country, Texas
Gotta be the springs. I agree with the prior recommendation to replace springs and maybe add a helper bag.
"If at first you dont succeed, come back with a big damn stick". -My Dad
I've been thinking about this issue for a couple days. Loosing sleep on it actually. So I finally got around to googling some images of what the rear sway bar is supposed to look like. Study this pic. Then look at the pics in the original post...
Something is totally wrong. That doesn't even look like an H3 sway bar! Its bent completely 90-degrees from where it should be. What the hell?
Azon...not sure what you got there but, it ain't Hummer. Take it off and put a stock one back on.
4speed look at a T sway bar...there different. I assume they are up like that because of the spare tire... His is pointed down. They should be straight up like this.
I would pull it off and reinstall it....it seems like its upside down. Is the sway bar like the pic when it's unloaded?
Ahhhh....yes. Check out the green tag with the bar code on it....its clearly bolt-on upside down. Jeez...how does this stuff even happen?
I would flip yours...I wouldn't be surprised if it was installed improperly during the lift seeing the ass hat screwed up your torsion bars too.
TAPDH3T
Texarkana, Texas
That agitates me!!! Man if I wasn't lazy I would drive back to Austin and me and Ol boy would have words!!!
Could of seen it on the LCC run...lol spring over like me but with stock hangers and $1300 worth of shocks compared to my pile of **** ranchos lol
Medic_Morgan
San Diego, CA
Damn I really wanted to make it but we just moved from Fresno to San Diego so I was tired of driving :( I really want to do a SOA like that if you can help me Chris.
Sent from my secret lair bwaaahhahahahah
Azon
Sweden
Jupp its up side down, I mounted it on right way and its no conflict with rear axel, but now I need to mount airbags suspension to support the weight of camper. Try to mount this tomorrow. So what is the weakest point of H3T if you overload it, axel , suspension, frame ??
I can help, for staying with ifs I would ditch the stock hangers and he said the angled shocks aren't worth it for a 3. Just 2 will do the job
