Questions on some subs
Bananatank
Hammond,la
Hello everyone, i started this thread to ask a few specific questions on some subs i was looking @ for my h3.
1) first off these are the subs i was looking at http://m.ebay.com/itm/ROCKFORD-FOSG...-ENCLOSED-CAR-STEREO-SUBWOOFERS-/171389790633 they appear to be plenty enough bass for me, but then again idk much abt bass so if anyone has purchased some subs similar to these would you suggest them??
2) I also need an amp for these subs and have no idea wtf I'm lookin for so if someone can help me do that, that would be great! (I'm going for a decently cheap but a good system btw)
3) last question, can i run these aftermarket subs and an aftermarket amp (once i find one) on my stock radio? Or will i need an aftermarket one to run these two systems? Also if anyone has a picture of a setup similar to these could you share it? I'm trying To not take up a lot of cargo space bc i use it pretty regularly.
4) i think thats everything but I'm sure I'll have more questions [emoji23][emoji88]. As usual, thanks guys!
USMC_315
Northern VA
I have a Kenwood Amp, couldn't find the model online and I don't have the deuce with me now. I also built a custom box to hold three 10" subs, it has more than enough bass for me. I got most of the stuff for around $1,000 and had my buddy install it for free. I didn't do any of the wiring so I can't help you out with that. However, I did not have to change the head unit in my 2. I also had this same exact set up in my H3 and didn't have to get a new head unit either, hope this helps.
Bananatank
Hammond,la
Quick question should i or should i not get a new hu if I'm planning on running subs? If yes where is a cheap place to buy a good hu, and all the material needed for the install or should i but that separate (like the plug in so i can keep onstar and all the chimes, and the double din mount)
USMC_315
Northern VA
I would say no, keep the head unit you got if its working. I kept the stock head unit in my 3 when I installed my subs
Bananatank
Hammond,la
Okay thats what i was curious about so basically all i need is an amp and subs I've picked out the subs now I'm looking for an amp[emoji106]
