Reaper's H2 Build
Reaper550
Fort Worth
Hey all,
So I picked up a 2006 H2 that had been treated well, just over a year ago, and wanted to transform her from a mall cruiser to a gentlemanly bruiser befitting a Reapers rig. Its my daily, so it needed to encompass looking at home in an urban executive environment as well as perform off road without looking out of place. I've got some big plans for her in store, but here is what I've managed to accomplish in the meantime.
So far:
  • Dash trim repaint to similar level of a mercedes piano black gloss
  • Front dash, A, B & C pillar retrimmed in black suede
  • Blacked out side markers, turns & rear lights
  • HID headlights
  • LED DRLs
  • Fox 2.0 shocks with remote reservoirs, plan was to be able to move quickly over rough terrain
  • Steering dampener upgraded to bilstein unit
  • M1152 wheels & tires with runflat inserts
  • 3/4 blacked out grille & satin body matched skid plate
  • All interior lights done in red LED
  • Nerf bar delete
  • Rear tail light guard delete
  • Sunroof visor delete
When I bought her:
Reaper550
Fort Worth
M1152 24 bolt wheels, runflats & Good Year Wrangler MT/Rs (kevlar lined sidewalls), running 2.5" billet spacers, FYI the wheels with tires & runflats are around 168 lbs.
Reaper550
Fort Worth
Next came the lighting upgrade, LED full time running DRLs (jumper wire), HID headlights:
Grille work & blacked out signals/side markers/rear lights, had the grille wrapped in vinyl to see if I liked it, now its getting painted for a permanent mod. I wanted to delete all chrome, but leaving 1/4 of it gives the front end the pop I wanted, without turning it into a black hole. I tried to match/balance a bit of it to the rear D rings & plate top, handles & mirrors etc:
Reaper550
Fort Worth
Did a full degrease & wash on the suspension parts & engine, love to see her nice & clean, then replaced control arm bump stops & started suspension work:
Reaper550
Fort Worth
Decided to blackout the skid plate, visually I feel it lowers the look of the rig to appear more slim top to bottom with more of an H1 type feel as it doesn't look so thick vertically:
Before/after:
Process starting with sanding the oxidation off, (pics of beginning of sanding down the middle):
Self etching primer:
Flat/Satin black base coat:
Reaper550
Fort Worth
Final color:
Conversion to red LEDs for all interior lights:
Reaper550
Fort Worth
Dash update to piano black, eventually I went to recover the front dash & cluster top to be black suede material to reduce any glare, while in white sealer I test fitted to see if black & white contrast looked good...nope lol:
Reaper550
Fort Worth
Dash continued:
Reaper550
Fort Worth
and finally in black:
Reaper550
Fort Worth
I was able to gain a decent finish and still have to go back to cut & polish to get rid of a bit of orange peal here and there but a definite improvement over stock I think:
Reaper550
Fort Worth
More dash work & a few road trip shots on my way to California, as I got to open carry on the way :)
Reaper550
Fort Worth
Suffered a few de-laminations from the MT/Rs, so I have a graveyard of wheels (4 blown, 2 loose rims) and i'm going to powder coat a set then replace the ones on the truck with fresh tires/runflats. These tires have a history of being indestructible, I run them at 28 PSI front, 26 rear to get full contact patch; still trying to figure out what is causing the blowouts. The hazy pic is at night after a 85 mph blowout on a right hand sweeping turn...crossed 3 lanes and luckily after the overpass I made it onto the median which was soaked, fighting the truck to a stop. Once damage was surveyed, I limped my way to a truck stop 3.1 miles away on the runflat. The trailer I was towing was around 5,500 lbs.
Reaper550
Fort Worth
When the rear tire blew (on the road trip to Cali) when I was pulling the trailer caused some damage to the left rear inner fender well:
So, gym time was in order:
When in Tx I rented a car and drove up to my contact in OK to grab a new wheel/tire, whole setup mounted & balanced with runflat was under $200 with a 99% brand new tire. Barely fit in the trunk lol. The tires that blew were are from a guy in east TX. The OK contact is the only contact I'll get military wheels/tires from now. Here's a look inside a setup that I ran a few miles on after a blow out, 28 miles at 65 mph getting the rig to the airport so I didn't miss flying out from TX to Cali for my son's first birthday.
Reaper550
Fort Worth
This one happened at the top of a trail at Big Bear after some rock/mud fun, it got us all the way down, then the few miles on tarmac to the cabin to put the spare on.
Updated the spash screen on the navi to my old company logo before they sold out (once Prince left, it all went sideways), second shot, I used the former phone speaker hole in the roof to mount a mini iPad while on road trips for map info
All in all, this truck is the best purchase of my life (guns included), H2s are an experience, a perfect compliment to a severely active life, so here's a few random pics road tripping from Tx to Cali etc. and a shot between high end halogen headlights & HIDs.
USMC_315
Northern VA
If I ever get myself another H2, it will look exactly like this. Honestly the best looking H2 I've ever seen, especially love the red interior lights. Job well done sir
I have run those tires before ( several sets ) and never had a blow out issue. I did run 35 psi. Did not get great tread wear though. My truck weighs about 1500#s more than an H2. Eric is back in the states now.
