Open the access panel
Reach back around to the back on the left
There is a plastic box holding the lock and on the left of the box towards the top you will find a vertical rod
Follow the rod down until you feel it align with the box at the bottom
There will be a cantilever/elliptical piece, it has a notch
Rotate the notch down and you may have to pull in that rod a little if it’s tight or binding
Works even if the door is locked and power is off
