Removing headlight and wiring question?
rsm688
mississippi
What is the best way to remove the headlight assembly from the headlight bracket (while still on the vehicle)? It looks like there are three clips on the back holding it in place and there is some other larger thing on the other corner. Do you just pull hard on it? I gave it a little pressure and it didn't budge.
Also, any ideas on a good wire that is on with the key under the hood? I am installing HALOs in my headlights and need a wire that is on when they vehicle is to run my power for the HALOs.
Thanks,
Spencer
derian06
Red Rockett
Madison, AL
Thanks,
Spencer
I wired halos on my old H3, I can guide you through the process if need be. If you pm me your number I can text you about the process.
But first things first, it will be a pain in the ass and you will break the sides off your headlight unless you buy a new set.
