SolidusJ
- FT. Carson, CO
Rear defroster hasn't work after a hail storm or maybe even before that. When I picked up the T, 2 years ago now. The driver side connector to the window wasn't attached.
I've scuffed up the two connecting points and reattached using some specific defroster adhesive. The light illuminates when turning on the defroster.
Continuity test to the relay shows that its in good working order and the fues is just fine. What eles should I look into on fixing this fault?
Thank you.
Thank you.
