- Scottsdale
That's kinda what I was wondering.
This is addressed more towards Hunner, but I'll throw it out there for everyone. I'm not really sure what welding the half sleeve to the strap is really going to accomplish unless you have a fitment issue like I did. The only reason I welded mine is because since I was using only one half of the sleeve, it's no longer captive. That's the only reason I welded mine-- so it wouldn't fall out. It doesn't cause it to tighten up any more.
In your first picture, 08H3, I can see the sleeve is not not conformed to the strap clamp.
Is your steering wheel straight? You have spaced out the rack some from the stock location, I believe.
Interesting. I guess I had made the assumption that's the way it was supposed to be and by tightening against the rack, it would expand outward to tighten. I'll take your word for it that it should be different, BUT I will also note this. Thinking the strap might have been deformed when your sleeve didn't initially fit, I bought a second. Dimensionally, it looked the same as the old one and the sleeve fit the exact same way, so I don't really think it's a strap issue. Somewhere around here, I have a brand new RHD strap that I ordered by mistake. If I can find it, I'll see how the other half of the sleeve fits in that one.
I think if you have your driverside fixed alone you will be fine. Even if I had no clamp on the passenger side I only get as much movement as the rubber bushings will allow me to move (maybe 1/4-1/2") It sounds like you have a structural metal issue where your rack bolts to the frame.
backcountry That might be spring!
08H3 quote What I can say is that the rack isn't forced out to fit the plate behind it. The plate slides in without issue. quote
Ok, in my case I have to pull the rack away from the frame to put the sleeve in but only the same amount that the OEM rubber spaces it out.
All this input is great. We have covered a lot of things and I think it has helped others to understand how this should be done.
I have felt somehow I was not explaining well. Maybe sometimers? or I ass ume too much that even with my long explanations I left something out?
I'm trying and have sent lots of pm's and emails.
Once it stops snow/raining here I'll go tear it apart & find out!
I was concerned if I edited out the responses that go along with my suggestions it might not make sense in some of the replies. I don't want to have to edit all of those.
I will try to work on that in my sponser thread as I have lots of options that I can control. I might start there with only my updated info.
I already try to keep that up dated.
Right now I'm going to see if I can find some mud to wash these new tires in!
Links for more info on this fix by others.
http://www.hummer4x4offroad.com/foru...l-with-a-twist
http://www.hummer4x4offroad.com/foru...ssue-on-the-H3
http://www.hummer4x4offroad.com/foru...estion-problem
Ha, well this one is far from being done.
