Steering rack install help and suggestion.
I am installing a new steering rack and I removed the old one from the plate that has a single bolt with both ports, should I replace the O rings or are they OK to reuse? I will be replacing the pump too and has anyone flushed the system and how?
I reused the ones on one of mine but had to replace them on the one on the other H3T. I will call Dwaine and see if he has some in stock and if he does, I'll mail you a set.
You're talking about the Hydraulic fitting where it bolts to the rack body? If so...NAPA has a good selection of o-rings. Just pull your old ones off and get new ones that are close (or slightly fatter) than the originals.
