- Tardville
Same here. I'll sell you a "builder kit". Expect lots of cutting...lots of welding...some cussing...some head-scratching. My current design is coil-spring & shock only...but, I can delete the coil spring stuff if you want to run coil-overs instead. It uses a GM Dana 44 housing, ABS compatible, retains stock H3 brake system, yada yada. Prices are all over the place...depends on what parts you want...and how crazy you want to get with your axle build. I'de say starting at $700 for a basic bracket kit...up to $9000 for a full-tilt cro-mo shafted, locked, pre-assembled axle and all the goodies.
Later this summer I'll be removing the axle you see in that video. It will be for sale at some point...either stand-alone or with a complete suspension. Its been installed for over a year...works great...5.13 geared, Eaton E-locker, stock GM 3/4t shafts, Warn lock-outs, HD yoke, Flat-tops, Cast rock cover. Its been a great axle but I have a new hi-pinion version ready to swap in.
The new axle has Eaton's 4-spider E-locker (just released), Yukon shafts and super-joints, plus I'll be adding ram-assist to the steering. I want to try to drop the lift down an inch or so during the swap, and I plan to finally add some sway-bars to the mix. Not sure when I'll get around to it. Soon I hope.
