- Scottsdale
People ask me this every now and then, so let's see what I can come up with off the top of my head. Here's my replacement parts from wear and tear and breakage.
140,000 miles, almost eight years, only driven to church on Sundays.
2x Radiators
Water pump
Power steering pump
Steering rack (and about ready for another)
Crankshaft seal
Cylinder head
Thermostat
Exhaust manifold
3x right engine mount
2x left engine mount
2x hood support struts
2x left upper control arm
2x right upper control arm
Left lower control arm
Right lower control arm
3x front shocks
2x steering rack bracket (1 OEM, 1 PCF)
front diff
5x front half shafts (1 actual breakage, 4x torn CV boots under warranty)
4x half shaft seals
5x diff crossmembers (4 OEM, 1 PCF)
3x right diff support (2 OEM, 1 PCF)
2x left diff support (1 OEM, 1 PCF)
2x front propshaft (1 damaged, 1 shredded CV joint)
Front propshaft u-joint
Transmission
2x transfer case (1 rock through case, 1 internals through case)
2x rear driveshaft u-joints (replaced at same time)
2x rear shocks
Rear leafs re-arch and add-a-leaf, 6 new bushings
Front and rear sway bar bushings
5x tires replaced under road hazard warranty for cuts
Five new wheels (old ones thrashed by rocks)
5x windshield
Driver's mirror (Rock 1, mirror 0)
1 skid plate (bent beyond repair)
4x battery
I haven't included the maintenance list, or strictly upgrade items (like adding rear locker and doing basic maintenance at the same time)
2x Radiators
Water pump
Power steering pump
Crankshaft seal
Cylinder head
Thermostat
Exhaust manifold
3x front shocks
front diff
4x half shaft seals
Transmission
2x rear shocks
5x windshield
4x battery
