Tire Help Please
Peep
Belize
ok, I hit a Chupacabra by mistake. Anyway its about time I get new tires. Here in Belize they sell summer tires, used summer tires, and can even order in new or used summer tires. In stock there biggest size is 215/75r 16. Hum.... no way!
So I need to order or drive to Mexico and search so I need some advice please.
I have a 2006 H3 hummer levelled with 2" lift shackles. What can i get without effecting the fenders. Prefer all season for my odd trip to B.C. Canada which winter rated tires are required by law.
Was thinking some 315/75r 16. Any suggestions or experience will help. And if you know of a tire place that ships to Mexico would be good. Belize has tire import tax.
I believe pretty much anything in 315/75/R16 should fit absolutely fine, most you might run into is rubbing on the front sway bar when you turn the wheel to full lock.
GreatDaneHummer
Chicago
Keep your gas mileage and engine power if your doing that amount of driving. Stick to 285/75/16's then. Lots of nice ones on the market; can't go too wrong...
