I used the $7 a can Rustoleum "Professional" undercoating on my custom UCP. It hardens pretty well, and is easy to reapply when you scrape up the UCP since it sprays well in any direction. Just don't go with the cheaper $4 a can Rustoleum undercoating, it doesn't harden completely (stays a bit tacky) and goes on like crap. I was able to apply the professional stuff in cold (below 40 degrees) and still have it go on nicely and dry well, albeit it took longer. I accidentally used the cheap stuff for the last little bit of work and it was just terrible to work with.
I wouldn't bother with powdercoating them after welding on the Thor plates, I think they'd have to strip the UCP completely down first and then coat them, way too much money in my opinion. Plus after you scrape you'll still only be able to spray something on. Powdercoating is really only good for new manufacture.
You could paint them after welding with a good epoxy paint like Rustoleum as well, but I prefer the undercoating as it will hold up better to the elements.
Others will surely have different opinions, but the consensus will probably be it doesn't matter as long as it's covered.
