rsm688
- mississippi
Okay guys I've noticed every now and then when sitting at a red light or in in my driveway my idle will drop down for like once second and feel a little vibe/shutter come from the motor. It only lasts for a second and just occasionally happens. The H3 runs fine otherwise, its an 2006 with 96k miles. I did notice there was a good bit of black soot in my new exhaust pipes after 1000 miles but it had been sitting for 6 months and I ran some seafoam through it, new plugs, cleaned the MAF, cleaned the throttle body, Air Doc intake, new idler/tensioner pulley/belt, AFE filter, cat back exhaust, new oil with a little Marvel Mystery oil so was thinking that was just carbon buildup blowing out.
I've also noticed if I press the brake pedal hard and hold it for a second it will sometimes idle down a little too for just a second then come back.
And if I hold the power window switch up when the window is all the way rolled up it slightly idles down for a second too then comes back (new optima battery installed)
If it just slightly idled down from the window switch/brake pressing I probably wouldn't think twice about it but the little random sitting at a red light idle drop/vibe/shutter makes me want to look into it a little more.
Anyone have any ideas on what might could cause that?
Thanks,
Spencer
Thanks,
Spencer
