They are NOT the trailer brake connections. Those are four blunt cut and taped wires up under the dash to the right of the steering column. (Bk is ground, D-Blue is from controller to rear trailer plug, RD is from 30A fuse and L-Blue is signal wire from brake switch).
The 4-pin blue connector is the clutch start switch; I believe it has a pink wire in terminal A and that would be ignition 1 and B is the signal to the computer.
The 2-pin black connector is the Clutch position switch and Terminal A (I think) is also a pink ignition 1 wire and B is the switch signal for cruise control
