What's everyone using for Extra Lights, Show off your rig!
Chook
Brisbane (Australia)
Headlight upgrade to ARB IPF "Fat Boys"
4 x Lightforce Striker on top
3 x Narva LED sides & back
Chook
Here is more info on the Fatboys.
It is a simple bulb replacement (they also have a loom upgrade but I found I didn't need it on the H3)
The reason I upgraded them was to upgrade low beam. (When I came off high beam with the Lightforce I was literally blinded)
The Super Clear bulbs perform at an optically equivalent level of a 195/150 watt bulb even though it has a low beam draw of only 80 watts and high beam draw of 60 watts
http://www.arbusa.com/uploads/PDF/newProductAdvice/fatboyII_media.pdf
Chocflip201
In the Rocky Mountains
Utah
I picked up some more LED's to put on my H3, they aren't mounted yet but I hooked them directly to the battery to test them. They are aimed in the same spot here but when they are mounted their light will be spread out. Don't mind all the $hit on the side of my dad's house.
i'll add more pics of all my lights when I get these installed.
Chook
Chook that antenna would drive me nuts! Love the lights though.
We drive on the other side BTW
Its on a tight spring and doesn't move (except when I use it as a feeler gauge. I got the antennae the height of my rig so it tells me where my rig wont fit)
I bought the black one so it doesn't reflect the light.
These are some LED light I hooked up inside my RTT so we don't have to have a bunch of head lamps floating around.
One on either side:
Both are individually switched:
Welcome!
Go to the intro forum and post up some pics of your rig!
Does that go on the inside of the headlight or outside??
4x KC spolights up top
2x KC driving lights down low
They currently don't work since there are some shorts and corrosion and or bad relays somewhere and I haven't fixed them yet.
