GoBlueHummer
- Michigan
I just replaced the rear spring bushings and the upper shackle bushings along with Schwarttzy's extended shackles and here my 100,000 miles and the Michigan salt and rust made it look like yours before I started.
Prepare yourself mentally to buy new bolts and use a sawzall to (carefully) chop the old shackles out and (very carefully) chop the walls of the bushings enough to press those out too. Only one of four bolts came out of the bushing, the rest were rusted to the center sleeve and tore the rubber when I tried to unscrew them.
Also, prepare to buy new rear shocks, as the bushings on those tore as well.
Also, the front bolt on the driver side leaf spring can not be removed without dropping the fuel tank, so maybe be nearly out of gas before you start the project.
It's recommended to install it facing the other way when you put it back, so it isn't as annoying the next time, if ever.
Good news for me though, my rear suspension is practically new now!
If I could do it again I probably would have just bought new springs so I wouldn't have to worry about the bushings.
Oh, and you will need new U bolts too, I hear.
Here's a thread with a bunch of part numbers and info. You'll discover that the 2009 H3 has less expensive leaf springs. Nobody knows why, they should be exactly the same and work on all other years.
http://www.hummer4x4offroad.com/forum/showthread.php?5608-Leaf-Spring-bushings
I had that issue when I replaced my UCA. I fought 1 side for what seemed like hours before I finally applied PB Blaster pretty liberally. Left for 30 minutes and came back to a bolt that was easily knocked out with short blows with a hammer. Doused the other one prior to starting to mess with it and it came out easily.
Just a thought and a little less work intensive if it works out.
