H3 led light bar mounts...
poweraidon
georgia
What are these things?
I concur - rivnuts. Drill a hole barely larger than the nut, use the bolt, nut and washer to put them in place. Honestly, they should have instructions (and the drill bit). if not, thread the bolt into the rivnut with the nut above the rivnut. Insert the rivnut in the body hole, then tighten the nut - that will compress the rivnut like a pop rivet.
I wondered how that was attached.... now I know. I've those brackets on order as well...
poweraidon
georgia
Ok so I drill a hole then insert the rivnut in the hole after that I get my mounting bracket and line it up with the rivnut and use the bolt to tighten it?
derian06
Red Rockett
Madison, AL
You should defiantly post detailed instructions on how you did it after you're done with pictures.
Not a bad idea I would be down for a set. Let's get together and I wouldn't mind putting in the leg work with to get a group buy.:cheers:
Im in for a set if they ship internationally. Will just need to figure out a way to mount my 40" on it. (Maybe mount it on those 50" U cradle with one D2 on each side)
Chocflip201
In the Rocky Mountains
Utah
Use the existing hole in the pillar, and bolt the bracket to the pillar using that one hole. Use that as alignment to mark the other two holes per each bracket. (Either with a marker or a hammer/punch in the center of that hole) then REMOVE the G2 bracket, drill the two new holes in each side of the A-pillar. Insert the Rivnut into the hole, tighten down the Rivnut to install it permanently into the sheet metal, then bolt on th G2 bracket again.
poweraidon
georgia
So after I drill the the hole and insert the rivnut into it won't it just fall out? How do I tighten the rivnut
poweraidon
georgia
What are all these other bolts for if all I need is the rivnut and the black bolt
poweraidon
georgia
I get it now... Had to do some research on rivnuts lol. Never heard of them before
SolidusJ
FT. Carson, CO
I got a high quality import light bar that has worked great for almost 3 years and counting. I don't understand why everyone thinks that everything foreign is garbage and everything american made is amazing.
I RATHER BE DEAD THEN RED!!!! RI has some china stuff in it but I haven't seen the cheap ones make a video like this.
[video=youtube;wuIU-Mg0EMM]https://www.youtube.com/watch?v=wuIU-Mg0EMM[/video]
SolidusJ
FT. Carson, CO
Holy carp that's not a bad idea, think you could draw something up so I can get a better idea? I have two 4" and four D2.
...but if don't buy 'Merican you ain't 'Merican! :D ...does that remind you of anybody? :cool: LMAO!
Im sorry about the drawing part, but below is a picture of the U cradle:
We can mount the 40" in the middle of the cradle, and one D2 on each side. If the D2s mount like the Auroras I have:
Then the D2s body can probably overlap abit over the base mount of the 40" light bar mounts hiding part of it, and you can have them pointing slightly sideways for more side coverage!
The cradle can then be mounted directly to the G2 mounts.
Offcourse thats ALL talk, but unless I figure out a way to sell my 40" and wait for a 50" (or an alternative way to mount them), this is what Im planning to do.
poweraidon
georgia
I called some of the local shops and some of them tried to rip me off because it a hummer saying it'll take 3 hours to install... I really wanted to call them out on it but I kept my calm
SolidusJ
FT. Carson, CO
OK I'll work on some plans and they can to ship to you.
SolidusJ
FT. Carson, CO
I called some of the local shops and some of them tried to rip me off because it a hummer telling it'll take 3 hours to install... I really wanted to call them out on it but I kept my calm
I know if you get the RI it comes with harness and button. If I was closer to you I would knock it, hardest part is where you want the button. :wink:
