2006 h3 won't start
justintaylor
utah
I have a 2006 h3 that won't start, when I try and start it the throttle body makes a clicking sound and the car won't turn over. I can't jump it or anything. The battery is reading just fine as the radio and everything works just fine. Any suggestions on what I can try?
Could be a broken battery too where it's putting out enough voltage to run accessories but not start the vehicle. Do you have an aftermarket alarm on there?
derian06
Red Rockett
Madison, AL
X2 everytime i've had that clicking it was always the battery. Try getting a jump and see if it starts.
joekicksit
Chino,California
Sometimes my 06 H3 does the same thing and I literally just lightly push my shifter knob? ( idk what its called) forward towards the radio and then turn the key and it turns on every time!
chaos254
Check the connections and test the battery. The radio and lights can work even though the battery doesnt have enough cca to start the truck
Like derian said, can you jump it to get it started?
justintaylor
utah
On my way to the local store to get new connections now. I have tried jumping the vehicle and it will not start. I will see what happens with the new battery connections shortly!
Passlock possibly? Is the security light blinking in the dash? Computer will not allow the starter solenoid to engage if you are too low on voltage, but attaching some jumper cables should have fixed the low voltage issue. Confirm the clicking noise, the throttle body shouldn't make any noise.
Can007
Palmdale, CA
This has happened to me once or twice and it has to do with the ignition switch malfunctioning and send the wrong signal, resulting in the security setting to kick in. I had to wait about 15min and try again and it turns on.
