H3 sway bar disconnects
little h3
missouri
little h3
missouri
Dang that's not good how did you prevent that from happening again. your running the Rancho lift right, how do you like the ride on road I would like to buy one it's just not in the budget right now,
derian06
Red Rockett
Madison, AL
No idea what I can do to prevent it, as of right now I put the clips back in and have duct tape holding it up... I guess the spring over will eliminate any rubbing i'll ever have. Also the rancho lift was fantastic when I first got it, then I switched to the mtr with kevlar and the ride is a little worse than stock, but better than the T-bar crank. But I wouldn't trade the lift for the world, well worth it.
derian06
Red Rockett
Madison, AL
Why is the Rancho kit ride worse than stock with the new tires?
Alot more bouncy, alot of little vibrations. I mean it's a stock 32" A/T vs. a 37" M/T. It makes sense, the rancho with the 315/75/16 km2's had an amazing ride. Also I have no rear sway bar so that could contribute to it aswell.
Panzer07
Ontario, CA
What PSI you running I have the. MTR's in 35"s and the ride is awesome I run them a little high 40 and the ride is good a lot smoother at 35' but sometimes I get the tire light when. Running 35 psi...what I did notice is that they are getting a little bit noiser than when they were brand new. But not too much.
Torres
derian06
Red Rockett
Madison, AL
Torres
I was at 33 and it was really bad, dropped down to 25 and now they're better.
derian06
Red Rockett
Madison, AL
Haha alright man, I would strongly advise against that, as that will prematurely wear down the tread compared to a higher psi
I thought about that, but I'm also running an 8" wide rim. When at 33psi it looks as though not all of the tread is touching the pavement. 25 looks alot more even, any thoughts on that? All the different forums i've read have the same experience with 37's. I'll have to do the chalk test I guess.
