How did it rip the plastic under the door off, in my pictures only the rear is undone , I did undo the front and test it out too but didn't take pictures of that yet
Dang that's not good how did you prevent that from happening again. your running the Rancho lift right, how do you like the ride on road I would like to buy one it's just not in the budget right now,
Why is the Rancho kit ride worse than stock with the new tires?
That sounds like a tire problem not a lift kit problem
What PSI you running I have the. MTR's in 35"s and the ride is awesome I run them a little high 40 and the ride is good a lot smoother at 35' but sometimes I get the tire light when. Running 35 psi...what I did notice is that they are getting a little bit noiser than when they were brand new. But not too much.
Torres
I was at 33 and it was really bad, dropped down to 25 and now they're better.
You meant you dropped them down to 35 right? Because 25 is way too low for normal driving
Nope took them down to 25 psi, 33 was god awful on the road.
Haha alright man, I would strongly advise against that, as that will prematurely wear down the tread compared to a higher psi
