Badge removal
ENASNI
Jerseyville, IL
Are any of the badges bolted on? I want to remove both side badges and the gate badge. I'm guessing they're just on with double sided tape but thought I would ask first.
650Hawk
Don't know about the others, but my rear Alpha badge was double sided tape only. I used fishing line to saw through for removal (replaced it with a special edition "V8" emblem). I assume that they are all attached the same.
CaddyStrophic
I've completely shaved 3 H3s and all of the badges are held on with very strong double sided tape.
Use a heat gun and nylon prying tools. If you take your time and do it right, they will come right off, no problem. The badges will be ruined, though.
ENASNI
Jerseyville, IL
Took a little over 3 hours but I got them all off. Started off with fishing line to separate the badge from the truck. Then I used the heat gun to get the bulk of the glue residue off. Then turtle wax decal remover. Then finished it off with simple green and windex. You can't even tell anything was there. My finger tips are pretty sore though hehe
My badges came off perfect. I stuck them on my tool box incase I ever wanted to use them again. I don't see that happening though.
ENASNI
Jerseyville, IL
Why are you trying to hide? Wear your badge with honor. You can't hide what you are, you're a friggen Hummer owner.:horns:
650Hawk
After fishing line, I used Desolv-It; best adhesive remover I've ever found. My Alpha badge is now over my workbench.
Just figured out your license plate/forum name! Nice! :thumbs:
