With the recent flooding in my area, I went exploring this weekend driving through some flooded sections of roads. I didn't drive through anything above my rock rails because I didn't need to, but this led me to thinking about what are the practical fording limits.
I'd like to build a thread that has a comprehensive list of all the places water could ingress into something a do damage, starting from the ground level up. Or better yet, referenced in elevation from a fixed point like the rocker panel because that is a good visual reference point when you look out the window when fording and takes out the variability in ride height in various rigs. (Please don't tell me you have to have the windows up to keep water out, but I know some of you are outright crazy)
I'll throw out a starting list here as food for thought. All of these are below the rocker panel line.
Rear diff breather, connection at diff.
Front diff breather, connection at case
Wheel speed sensor, o ring
Rear axle seal and diff cover seal (safe to assume if oil stays in, water stays out)
Moving further up, no reference heights yet
Transfer case and transmission vent (where is the top of the tube and is it secure)
Rear diff breather tube (same thing, it terminates under the rear floor pan, height)
Transfer case shift motor electrical connection
VSS speed sensor electrical connection in transfer case
Transmission quadrant connector
Transmission main electrical connector.
License plate light and connector
Trailer light connector
Next up would probably start to be door seals once you cross that height. I don't have a stock engine anymore but I don't think there are any electrical connections down low with the exception of the transmission.
I know a snorkel looks cool, but to be honest, there are a lot of other vulnerabilities before water at the level of airbox height becomes a concern. As we all know, a simple electrical short could cause havoc, and disable an otherwise healthy mechanical engine, and stranded in water over the door seals would eventually lead to a catastrophe.
With a good checklist, it probably wouldn't take long to do an inspection to make sure everything single item is secure. Also if anyone else has had issues with water ingress (I recall a diff or two somewhere on here), this may be a good place to discuss how and why it happened and preventative measures.
