- Meridian, ID
Depending on the sensors you may or may not be able to fit them. JK sensors are flat. They can fit anywhere! If a 99 burb sensor is like an H3 you will have to probably go outboard on your rotor setup...if that's the case grab some H3 calipers, 2002 rotors off a Chevy 2500 and you will have better brakes then the factory stuff from 1978.
For me, I just mocked up my front 8 lug rotors to the rear, back to the DIY lathe -____- gotta trim them down...so The rotors for a 14 bolt/eaton disc kit are 12.5 diameter just like the H3 so now I gotta cut/move them out as well since my new ones are 12.9...Other issue, rear disc kit calipers are floating and the rotors are 32.4mm thick. The ones for the front are 29mm thick. Will this matter? Will the piston be pushed out all the way with more clamping force needed?? I don't know.
Now I know why CJ took months on doing his SAS for the first time, one problem, come up with a solution, modify, implement the idea. Past that, hit the next issue, repeat. This is why it's easy to build some trailer queen off road beast. Want quality brakes? Want to keep your dash from lighting up? Want to keep it streetable? Well it's tougher...but I know what's the plan for next weekend!
Btw CJ WMS is 65 rear 69 front. Was gonna throw 2in spacers and be even. Ran spacers for 75k miles never an issue. Had lots of other ones but never an issue with spacers.
Also before I forget I'm heading up to Northern California tomorrow morning for work. On the way home I'm picking up a new school 14 bolt for my brothers JK, 2002 14 bolt, modern brakes, full float, parking brake, 68 WMS. I will be giving it the same treatment. ABS compatible, Overkill beast. Then he's grabbing an 05 super duty front 60. Car part has them for 285 right now. Can't touch an old 60 for less then a grand and these are better but people view them worse since they have unit bearings and ball joints, but they are massive!!! And they are 35 spline inner and outer stock. Make that ABS compatible as well. Then my buddy is gonna take my brothers JK High pinion 44 front that's trussed, sleeved, gusseted, locked geared and put it under his TJ. Lots of axle tech going on, all while I gotta get panzers axle welded up too and SOA with my old rear axle.
