Ghostbuster
- United States
Hey Ghostbuster,
Cuting off the muffler (whether you install the 50 series or not) will only make more noise without a measureable performance enhancement. To improve power and economy, the crossover that goes from the left bank under the t'case tail shaft to join the other pipe has to be replaced. If you take a careful look, that pipe is crimped to the point of super restriction. One of the reasons it is crushed so deeply is to make room for the strapped on heat shield. If you don't want to invest in a catback such as MAGNEFLOW , a good exhaust shop can build a 2 1/2 inch crossover without the restrictive crimps. In either case, grab some DEI Titanium exhaust wrap because of the closeness to the wiring etc.. One engineer stated that this was the SINGLE item that made the 5.3 in the H3 to be rated with less horsepower than other GM 5.3's of the same vintage and also code 0420 showing up more frequently in the left bank.
Yeah I noticed that nice squished pipe.
The Flowmaster is already on.
Not the best weld job, but it is on. I can't hear any leaks.
It is pretty quiet.
Stock H3 Alpha:
https://vimeo.com/197514599
No muffler:
https://vimeo.com/197514668
Flowmaster 50 series: https://vimeo.com/197521155
