- Indianapolis, IN
Rear are pop in.
Pry out the old bump stop.
Jack up the frame on one side. Place one side in place with something to fill the gap between the stop and the axle. A chunk of 8x8 lumber worked well.
I just drove off the hump at the end of the driveway and backed up a couple of times. Then checked how the stop seated and adjust the liner and repeat.
Both sides only took one repeat to seat properly.
Front are bolt in and have a very thick washer. Put truck on Jack stand and put floor jack under lower ball joint.
Remove tire. Remove old bump stop.
The well above the bump stop has 3 bottom corners open for drainage.
Drop the not into the well and either in place over bolt hole. A flashlight hellos align the not. Hold in place with a screw driver.
Take bump stop, put washer in place and put into could. Start screwing bolt into nut.
I then used a 12 inch extension and universal joint to tighten nut.
It takes a little finess but it's doable without removing upper A arm.
The Timbren bump stop make the suspension quit a bit stiffer. But I like it and there's almost no body role when turning out of a driveway.
Sent from my Moto G (4) using Tapatalk
Ok cool thanks. Do the fronts fit into the one cup last the little prongs that are there to hold the factory ones?
