Schwarttzy, if the brackets are ending up being welded together instead of one piece formed without your knowledge, then you should hold the company/party responsible for the issue accountable and require them to provide corrected replacements or compensation. They were supposed to provide the product according to your specifications and if they failed to do that and covered it up then they need to be held accountable for it.
fanugy
Phoenix, AZ
This is correct, if someone fabbed these for you, they are on the hook for following your design. You may need to have a friendly face to face conversation with them, followed up with an email to reiterate whatever you agreed to. If they make it right in a timely fashion, it is resolved. If not, have an attorney send a demand letter.
You do not owe anyone anything other than replacing parts not manufactured as described.You owe those but should work it out on the back end with the fabricator- and it is likely not all parts are defective nor will all individuals who purchased one submit a claim- just like a recall notice. Perhaps, if you have the records, you send a notice to addresses where this item has been shipped before.
Finally got an order in with GOBI for replacement brackets for the rack and ladder, turns out my old emails had been going to their spam folder for some reason lol The old brackets were rusted/stuck onto my totaled H3.
Now to just wait for them to go through production. :thumbs:
Traxx
PNW
I'm finding it rather difficult to believe on such a low volume item like the skids that one wouldn't notice that the brackets were welded instead of one piece. It is a serious safety concern that could kill someone. What are you doing selling things things if you 'have no money' to back up the inevitable problems that arise?
fanugy
Phoenix, AZ
Wow. Time to back off. You clearly have no experience subcontracting materials or services and there has been no denial of anything other than shock over the situation. You clearly display a lack of understanding if you think every component manufactured, in-house or out, is blessed by the owner/orderer. Clearly something is wrong, but he owes you exactly ZERO until he can figure out the scenario under which it occurred- if it even occurred with his product. The faux rage/shock/“how dangerous” plays very, very poorly. And, just because you gritch and wine, a manufacturer will normally only replace your product once you return the faulty one. That is the remedy, not making you feel good or entertaining your outrage.
My torque converter was purchased, installed in front of my newly rebuilt tranny, and failed in 200 miles, shredding my tranny. The remedy owed me was a replaced torque converter after I removed the faulty one. I was not owed fluid, labor, self-righteous outrage, or the components of my transmission.
I’m sure lesser men could sue for such things. But this forum does not appear to be filled of those indignant, self-important types. Perhaps I am wrong.
Traxx
PNW
Feel free to be the guinea pig on having one fail at freeway speed. I have more experience running a business than you have years on the planet. Subcontracted or not your still on the hook. There are probably a whole twenty sets in existence if that. I'm pretty sure any normal person would have inspected what they designed and paid for.
No denial?
Here, I will copy it for you since reading comprehension isn't your strong point.
Originally Posted by lsv_palana
No ! they welded .. look on picture please - so you can see weld only on top of mount.. no weld on back side where spring ... moun broken in half on bad weld.. look on picture..
I can assure you it is not my part if it's welded.
Had your torque converter killed a passenger i'm sure you would be one of those self important lesser men.
Time to tone down the bashing and let the facts come in. I had the leaf spring mounts myself until my SOA and I can assure you that they were bent and not welded.
Vdawg1115
Oakland, CA
I checked mine last night and it looks like mine could be one of the welded ones. The inner bend looks too sharp to be a bend so I am assuming it’s a weld. I’ve already been in contact with Schwarttzy and I can assure you he’s doing whatever he can to deal with the situation. I am surprised mine has lasted as long as it has with all that it has been through, maybe mine was just welded better. But let’s be patient. He’s working on it.
Schwarttzy
Rockford IL
Wanted to update you guys on what has been going on.
Again, I apologize for my mistake.
Yes, there is welded leaf spring bolt plates out there that I'm calling version 2. I had completely forgotten about that change because I didn't exactly make the change, I just verbally approved it.
Below is Version 3, it will be bent like the original design so that it cannot have the same failure. It also has some minor changes to improve the ease of installation. To make it easier to manufacture, the shock mount is 1/4" lower.
While this decision this isn't final, currently the thought is that there was no penetration resulting in a poor weld which caused failure. Again this isn't final, but this is currently the only reported incident so far.
I plan to replace his High Clearance Leaf Spring Bolt Plates free of charge with the new design. Although I would want to know those particular ones are destroyed somehow because shipping them will cost a ton.
I plan to offer everyone $10 off every part they purchase for the next month with the idea to raise awareness and to check their High Clearance Leaf Spring Bolt Plates.
For anyone that ever has any issues with my parts, know that I will do everything I can to take care of you within reason.
Bowser-II
Hagerstown, Maryland
Erick
This is a good response and approach, those of us who have purchased your stuff are grateful for the products and also the known support.
Vdawg1115
Oakland, CA
It’s easy for everyone to forget that this isn’t even Eric’s full time job. Just something he does on the side for the betterment of the H3 community.
H3Wolf
Finished painting the lights once dry I'll add my runes and wire them and put them on. Took a huge risk on using my headlight housings but I think it paid off.
Sent from my Moto Z (2) using Tapatalk
H3Wolf
how can you do that ? please teach me..
I'll do a write up soon, once it's done. It's a risky process, I would recommend everyone who would do it this way to not rush and have an extra pair of OEM headlights
lsv_palana
Kamchatka, Russia
Hello again, my dear friends.
Some of you bought sibirean bushing maded from polyurethane. Also i bought them. now have a plan to install whole kit. i found bushings for front axle to but did not found bushings for body.. does anybody know where i can find polyurethane body bushings ?
I don't think I've seen anyone make poly bushings for the body, just the suspension. Maybe reach out to Siberian bushing and see if that's something they'll make? Another option is to fabricate your own using universal poly bushings and a lathe.
lsv_palana
Kamchatka, Russia
Hello dear friends. I seek all around internet, but have nothing found. maybe anyone have sizing of these bushings ? i can use lathe for create these bushings by myself.
lsv_palana
Kamchatka, Russia
by the way. i have reached Siberian guys, that made bushings for Hummer h3. They said that there is no plans no make body bushings for our car - they did not shure that they can sell these bushings..
BW_Hummer H3
Texas
Finally got rid of the terrible/awful duratracs. Went with 35s toyos and absolutely love them. Way quieter and smoother. Gotta do a little trimming on the inner fender and mud flaps though.
